Neue Busliniennummern ab 2019!
geschrieben von B-V 3313
Hallo zusammen!
Einem internen Papier zufolge sollen ab dem Dezember-Fahrplanwechsel die Bus- und Straßenbahnlinien neue Nummern erhalten. In Anlehnung an Wien sollen die Buslinien, die in ein Haupt- und ein Nebennetz getrennt werden, mit den Präfixen A und B ausgestattet werden. Die Straßenbahnlinien erhalten den Buchstaben T (für Tram) vorangestellt. Paris soll dafür Pate gestanden haben. Das M verschwindet.
A0x: ___ = ___, 100 = A_1, 200 = A_2, 123 = A_3, 104 = A_4, 120 = A_5, 106 = A_6, M29 = A_7, M19 = A_8, 109 = A_9
A1x: 110 = A10, M11 = A11, 112= A12, 101 = A13, 114 = A14, 115 = A15, M48 = A16, 248 = A17, 118 = A18, 316 = A19
A2x: 221 = A20, M21 = A21, 122 = A22, 133 = A23, 124 = A24, 125 = A25, 222 = A26, M27 = A27, 128 = A28, 220 = A29
A3x: 130 = A30, 131 = A31, M32 = A32, 237 = A33, 134 = A34, 135 = A35, 136, 236 = A36, 137 = A37, M37 = A38, 139 = A39
A4x: 140 = A40, M41 = A41, 142 = A42, 249 = A43, 245 = A44, M45 = A45, M46 = A46, 147 = A47, 247 = A48, M49 = A49
A5x: 150 = A50, 107 = A51, 250 = A52, 255 = A53, 154 = A54, 155 = A55, 156 = A56, 350 = A57, 158 = A58, 259 = A59
A6x: 160 = A60, 161 = A61, 108 = A62, 163 = A63, 164 = A64, 165 = A65, 166 = A66, 265 = A67, 162 = A68, 169 = A69
A7x: 170 = A70, 171 = A71, 172 = A72, M44 = A73, 277 = A74, 260 = A75, M76 = A76, M77 = A77, 246 = A78, 179 = A79
A8x: M82 = A80, 181 = A81, 282 = A82, 283 = A83, 184 = A84, M85 = A85, 186 = A86, 187 = A87, 188 = A88, 285 = A89
A9x: 190 = A90, 191 = A91, 192 = A92, 893 = A93, 194 = A94, 195 = A95, 296 = A96, 197 = A97, 240 = A98, 399 = A99
B0x: 347 = B_4
B1x: 310 = B10, 218 = B14, 318 = B18
B2x: 320 = B20, 322 = B22, 324 = B24, 326 = B25, 327 = B27
B3x: 334 = B34, 234 = B35, 337 = B37
B4x: 341 = B41, 204 = B43, 309 = B45, 349 = B49
B5x: 350 = B50
B6x: 363 = B63, 365 = B65, 168 = B68, 369 = B69
B7x: 370 = B70, 271 = B71, 372 = B72, 373 = B73, 175 = B76, 377 = B77
B8x: 380 = B80, 284 = B84
B9x: 390 = B90, 291 = B91, 294 = B94, 395 = B95, 396 = B96, 398 = B99
Änderungen Expressbusnetz:
X33 = X23
Änderungen Nachtnetz:
N20 = N29, N22 = N26, N23+N39 = N39, N26 = N13
Die Straßenbahnlinien erhalten ein T vorangestellt. Aus M13 wird so z.B. die T13 und aus der 62 die T62.
Re: Neue Busliniennummern ab 2019!
01.04.2018 02:40
Ah, es ist wieder soweit... ^^
Nee, schon wieder alles ändern. Haben die Leute in der Verwaltung keine anderen Hobbys ? Das jetzige System ist doch bekannt und man findet sich zurecht. Die sollten sich lieber um die wirklichen Probleme im Nahverkehr kümmern, anstatt alles umzubenennen und Software neu zu programmieren. Sind eben Nieten in Nadelstreifen, gab mit dem Titel ja mal in den 90ern ein Buch.
Linienumbenennung, weil wir lieben doch alle Menschen.
Treffer!!! Schönen 1.April ;-)
Einem internen Papier zufolge sollen ab dem Dezember-Fahrplanwechsel die Bus- und Straßenbahnlinien neue Nummern erhalten. [...]
Da hast Du Dir aber große Mühe gegeben, Hut ab! ;-)
Allerdings finden sich in der Übersicht noch einige Ungereimtheiten. So finde ich es beispielsweise ziemlich gewagt, die Linie 108 dem Köpenicker Netz zuzuschlagen. Außerdem vermisse ich die Linie 269, für die offenbar das neue Schema keinen Platz gelassen hat.
Wollankstraße
Ich schätze, genau das ist des Pudels Kern: Die Neuprogrammierung der Software, die sich mit den alten Linienbezeichnungen immer sehr schwer tat und daher lieber eigene Kreationen benutzte. Um sie zu besänftigen, bietet man ihr nun andere Buchstaben an, in der Hoffnung, daß in Zukunft alles ein bißchen reibungsloser funktioniert. Durch den frühzeitigen Bekanntmachungstermin haben ja die Leute auch genug Zeit, sich mit dem neuen Linienschema vertraut zu machen.
Hallo zusammen!
N26 = N13
Da die Linie N13 bereits in Potsdam/Teltow fährt hast Du vergessen zu erwähnen, dass das interne Papier der BVG auch bereits auf das Umland ausgeweitet wurde:
Die VIP Linien erhalten ein P vor der neuen zweistelligen Nummer (P90) und die von Regiobus je nach Region ein PM, TF oder BRB usw.(z.B.PM31, TF22 bzw. BRB 81). Da diese Nummern nun aber nicht mehr in der Matrix angezeigt werden können, werden diese Anzeigen vorübergehend ausser Betrieb genommen und durch Plastikschilder an der Front und Seite ersetzt.
Kann ein Bus eigentlich noch fahren, nachdem seine OBU explodiert ist? Wenn nicht dürfte der Wagenpark zu Weihnachten ziemlich klein sein. ^^
Kann ein Bus eigentlich noch fahren, nachdem seine OBU explodiert ist? Wenn nicht dürfte der Wagenpark zu Weihnachten ziemlich Bin sein. ^^
Tihi :-D
Hoffe, das ist ein Aprilscherz. Habe bei ersten Lesen gar nicht auf den Kalender gesehen.
Wenn es ein Scherz war, war der gut. Bin erstmal drauf reingefallen. ;-)
1 mal bearbeitet. Zuletzt am 01.04.2018 12:17 von Wollankstraße.
Ich will das M ja schon lange abschaffen. Aber so?
Die Änderungen des Nummernschemas wären noch gravierender gewesen. Hätte sich Uber bei einer Ausschreibung zur Übernahme der Expresslinien durchsetzen können, wären diese in U umbenannt worden.
„Wir sind mit unserem Angebot bis an die Schmerzgrenze gegangen.“, so der Chef von Uber, Dara Khosrowshahi, gegenüber dem Tagesspiegel. „Doch die BVG hat darauf bestanden, der Bevölkerung ein X für ein U vorzumachen.“ Daraufhin habe man das Angebot zurückgezogen. Bedenken, dass dies zur Verwechselung mit der U-Bahn geführt hätte, wischte er beiseite: „In Hamburg betreibt die Hochbahn doch auch heute die U-Bahnen, und in Berlin wurde sie ursprünglich auch von der [Berliner, Anm. der Redaktion] Hochbahngesellschaft betrieben. Der Buchstabe H ist also noch frei, und macht historisch auch Sinn.“
Wie lassen sich künftig die 24/7-Straßenbahnlinien von den anderen unterscheiden?
Genauso, wie in London: Anhand der Liniennummer gar nicht.
Die Idee, mit dem Kürzel des Landkreises vor der Liniennummer finde ich aber nicht schlecht: War ja zu Ostzeiten auch in etwa so. Der 950er war der E-18 und der der 951er der E-26 (beide jeweils in MOL). Das System mit den dreistelligen Liniennummern stößt ja doch irgendwie an seine Grenzen.
Die Buchstaben waren aber die Autokennzeichen der Bezirke, nicht der Kreise.
Das ist ja heute egal. Die Idee würde aber bedeuten, dass man fünfstellige Linienbezeichnungen bekäme - und wenn dann noch ein Bindestrich bei sein soll...also nein, da finde ich das bisherige System doch recht gut. Und da es in Brandenburg keine sechshundert Buslinien gibt, dürfte da noch jede Menge Spielraum sein - sofern man bereit ist, Kompromisse einzugehen.
Ich finde es recht sinnvoll, anhand der Liniennummer gewisse Qualitätsmerkmale (im Falle Berlin: 24/7-Betrieb) erkennen zu können. Aber ich gehöre ja noch immer zu den Befürwortern des Metro-Konzepts.
April, April!
Es wird - zumindest vorerst und in dieser Form - kein neues Liniennummernschema im VBB geben.
Die Kreise hatten ja auch gar keine eigenen Autokennzeichen. Deshalb und weil ich nicht auf die damalige komplett andere Verwaltungsstruktur eingehen wollte, schrieb ich, daß es "in etwa" so war, was ja letztlich auch stimmt.
April, April!
Ich habe ziemlich schnell schon erkannt, dass es ein Aprilscherz ist. Die Idee dieser neuen Liniennummer ist an sich überhaupt nicht schlecht, da nach 14 Jahren wieder ein neues Nummernsystem eingeführt wäre. Von der Einführung der dreistelligen Liniennummern bis zur Einführung der Metrolinien vergingen ebenfalls 13 bis 14 Jahre.
1 mal bearbeitet. Zuletzt am 05.04.2018 12:04 von Henning.
Eigentlich sollte man Liniennummern möglicht gar nicht ändern. Diese Durchnummerierungssysteme sind eigentlich nur was für Nerds!
Kaum eine Bus- oder Bahnlinie in einer Stadt hat noch nie ihre Liniennummer oder ihren Linienweg geändert. Warum soll alles immer so bleiben wie es ist?
1 mal bearbeitet. Zuletzt am 03.04.2018 12:03 von Henning.
